PC stürzt bei Spielen ab und fährt wieder neu hoch
djhussein
Beitragvon djhussein » 05.09.2016, 13:55
Hallo erstmal. Es geht um folgendes. Ich starte Homefront Revolution und im Spiel stürzt es einfach ab bzw der PC und dann fährt er wieder neu hoch. Meine Daten vom PC sind hier :
System Information
Time of this report: 9/5/2016, 15:51:01
Machine name: DESKTOP-JRAA0I0
Machine Id: {1C364664-1CFE-45A3-9F7A-1C4111308DC4}
Operating System: Windows 10 Pro 64-bit (10.0, Build 14393) (14393.rs1_release_inmarket.160819-1924)
Language: German (Regional Setting: German)
System Manufacturer: MSI
System Model: MS-7885
BIOS: Default System BIOS
Processor: Intel(R) Core(TM) i7-5930K CPU @ 3.50GHz (12 CPUs), ~3.5GHz
Memory: 16384MB RAM
Available OS Memory: 16284MB RAM
Page File: 2294MB used, 16421MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.14393.0000 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Sound Tab 4: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GTX 980
Manufacturer: NVIDIA
Chip type: GeForce GTX 980
DAC type: Integrated RAMDAC
Device Type: Full Device
Device Key: Enum\PCI\VEN_10DE&DEV_13C0&SUBSYS_111610DE&REV_A1
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 12202 MB
Dedicated Memory: 4060 MB
Shared Memory: 8142 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: SMBX2431
Monitor Id: SAM0771
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
Re: PC stürzt bei Spielen ab und fährt wieder neu hoch
Beitragvon Andy_20 » 05.09.2016, 14:53
Was für ein Netzteil ist verbaut?
Beitragvon schmidtsmikey » 13.09.2016, 19:17
Laut den Statusbericht, den Du gepostet hast, gibt es keine Fehler. Ich konnte keinen Fehler erkennen.
